Once you have connected your InfoTrack account to Smokeball, learn how to leverage the integration to simplify your workflow and maintain compliance.
If you haven’t already, connect your InfoTrack account to Smokeball.
Order an InfoTrack search from Smokeball
- Select a matter in Smokeball, then select the InfoTrack tab.
InfoTrack will open in the tab. Select the All Services button on the top-right corner of the screen.
Select the relevant Title Searches option under the state or territory. Below is an example for NSW:
- Conduct your search and make payment.
Once the order is completed, you can view it in the Orders and documents section on the left panel. You can also view a Fee summary of the orders you have placed on this matter so far.
The disbursement fees will also populate in the Time & Disbursements tab in the matter.
Show InfoTrack searches saved to a matter
You can filter your documents in a matter to only show InfoTrack searches. To do this:
- Select a matter in Smokeball, then navigate to the Files section.
- Select InfoTrack next to the document search bar.
Note: InfoTrack invoices are sent monthly directly from InfoTrack. For invoice inquiries, contact InfoTrack directly.
Create a PEXA workspace
- Select a matter in Smokeball, then select the InfoTrack tab and select PEXA.
- Alternatively, click into the Matter tab, then select PEXA.
- Follow the prompts to set up a PEXA workspace through InfoTrack.
After setting up the workspace, selecting PEXA from the Smokeball matter will open it for you again in PEXA.
Learn more about PEXA.
Access SettleIt and Securexchange in Smokeball
SettleIt and Securexchange can be accessed from the Matter tab within a Smokeball matter. They are located at the end of the list along with PEXA.
If you have a small Smokeball window, select InfoTrack first to access these features:
Learn more about SettleIt and Securexchange powered by InfoTrack.
Access the AML Compliance Centre in Smokeball
The AML Compliance Centre provided by Infotrack can be accessed by selecting a matter, clicking the InfoTrack tab, and clicking the Compliance Centre button.
You will be taken to the following page to review any outstanding actions required to meet AML compliance obligations.
Learn more about how Smokeball is helping firms to meet their AML/CTF Tranche 2 obligations.
