Print tasks
Learn how to print a list of your tasks by using the Daily Digest or generating a printable .CSV file.
Print your Daily Digest
  1. Navigate to the Matters View and select Print under your Daily Digest (right-hand panel).
  2. Review the Daily Digest Print Preview and then select Print.
Generate a printable .CSV file of your tasks
You can export your tasks to a .CSV file and print this file out:
  1. Navigate to the Tasks View and use the filters in the left-hand panel to narrow down the Tasks you wish to print.
  2. Select the Export button - you have the option to export only the current page of tasks visible to you (Export this page) or all pages (Export all pages).
    Note: The Export button only appears when there are tasks in the list. If your filters return no tasks, the button won't display — adjust your filters so at least one task is showing.
  3. Name the file and select Save. You can open the .CSV in Excel and print the Tasks from there.
7 out of 11 found this helpful
