May 25th, 2026
The Contact Export report in the Smokeball Desktop App has been updated:
- Contact Tag filtering has been restored.
- You can now set a filter to Include Deleted Contacts. This is set to False by default.
The Referral Type field is now available in the Included Columns filter drop-down menu for the following Smokeball Desktop App reports:
- Lead - Closed Lost
- Lead - Full List
- Matter - Next Steps
- Matter - Next Task
- Matter - Summary List
May 13th, 2026
Version 9.17 of the Smokeball Desktop App is gradually rolling out over the coming weeks. It contains the following new features and refinements:
Measures to prevent duplicate contacts from being created
We have made some changes to contact selection on a matter and the process on creating a new contact:
When adding a contact as a party in a matter, the window that appears will default to a contact picker to select an existing contact. If the contact doesn't exist, click Create a new contact to proceed with adding them to Smokeball.
When entering the email address or phone number of a new contact, the system will search for any exact matches that already exist in your Contacts database. If there's an exact match, it will appear as a drop-down, allowing you to select the existing contact. This can be ignored if the phone number or email does indeed belong to a separate contact.
Right-clicking on a party in Matter Details now displays Add [party to the matter] instead of Add an existing [party to the matter].
The wording around editing an existing contact has been updated to distinguish it from the screen to create a new contact.
Staff registration improvements
We have made the following improvements to the process in adding a new staff member/user to Smokeball:
- The expiry date on registration links via email has been extended from 3 to 7 days.
The UI has been updated.
Faster loading for Tasks that are linked to Workflows
Tasks that have triggers connected to Due Dates and/or Assignees in a Workflow (e.g. linked to a matter's Settlement Date, another task's Completion Date, or to the Person Responsible) now update instantly when a user edits the source data.
Notable bug fixes
- Fixed an issue where the Billing widget was not displaying on Leads.
- Fixed an issue where duplicating workflows created duplicate tasks that were still linked to the original workflow.
- Pressing Ctrl+S or the disk icon on a Word document or Excel spreadsheet specifically opened from the PC's local drive will no longer save changes back to the matter.
- Fixed the behaviour in New Outlook where users have to manually click on the Edit (Pencil) icon in order to create a draft email.
May 7th, 2026
The Smokeball Web App has been updated with the following refinements:
- Cost of sale accounts can now be mapped and synced through the MYOB integration.
- MYOB account settings will now automatically refresh when the page is opened, ensuring users always see up-to-date account information.
May 4th, 2026
Archie has been updated with the following new features:
New Agentic Model
Archie's engine has been updated to better assist with complex queries and workflows. It will now work through your matter more deliberately, by:
- Checking if there's enough context in your matter before responding
- Giving clear signals when something isn’t fully supported
- Having stronger continuity across multi-step conversations
- Producing answers that are more complete and grounded
- Aiming to reduce the need for follow-up prompts and manual verification
In addition, Archie can now generate slide-style images to help summarise or visually present information.Â
Archie Word Add-in
You can now use Archie alongside Microsoft Word by installing the Smokeball Archie Word Add-in. This add-in contains many unique features dedicated to document review, and utilises the in-build Review feature in Word to help you draft documents and correspondence.
Learn how to install and use the Archie Word Add-in.
Create tasks, memos and events in Archie
Archie can now create tasks, memos and calendar events for your matter when prompted to. All actions require explicit user confirmation before execution.
Learn more about creating tasks, memos and events with Archie.
Ask Archie with your voice (Voice Dictation)
You can now use your PC's microphone to talk to Archie. Click on the microphone icon to start recording.
Archie Matter Widget
You can now access Archie from the widget panel on the right-hand side of your matter file.
May 1st, 2026
Following reforms by the Tasmanian Land Titles Office (LTO), two forms have been removed from the Smokeball Precedent Library (Court & Authority Forms > TAS Forms Land Titles Office):
- Transfer
- Application by Personal Representative to be Registered Proprietor
These forms are now generated through the Tasmanian Online Land Dealings (TOLD) system and are no longer available as downloadable, fillable PDFs. The PDF versions were phased out as part of the transition, which concluded on 16 February 2026, in line with the move to electronic conveyancing.
