Smokeball Grow and Prosper+ Releases November 2026
Plan_GrowProsper.svg
19th November 2026
  • You can now set up an invoice approval workflow in Smokeball. Assign staff members as approvers to review and approve draft invoices that all staff create.
  • On a matter’s Time and Fee entries, you can now change the staff, rate or matter for multiple entries at once, under the Bulk Actions menu.
    Notes:
    • Rates are re-evaluated against the matter's current rate set, not the rate that applied on the date of the work.
    • Entries on a draft invoice can still be selected, and the draft recalculates. Percentage discounts re-apply to the new total. A fixed-value discount that would exceed the new fee total is capped at that total; you will be warned of this before confirming.
    • Written-off entries can be changed as long as they are not on a finalised invoice or pending approval.
  • When logging into Smokeball via the Web App, the login screen now prompts you to enter your email first, then password.
18th November 2026
FamilyProperty has been updated:
  • Children's details and the Matter Owner now sync between Smokeball and FamilyProperty on new matters.
  • You can now choose whether emails are sent in the Matter Owner's name, with replies going to the Matter Owner or to one firm address.
  • Fixed an error when downloading documents from custom spreadsheet templates, and resolved a security issue in the questionnaire.
13th November 2026
Archie has been updated:
  • Archie outputs now keep their formatting.
    • All outputs: If you ask for formatting Archie can’t apply, like a typeface or page margins, it now tells you instead of silently dropping it.
    • Word: Tables keep their borders, column widths and full page width. Letters open on the firm’s template, and centring, underline, colour, highlight and footnotes carry through.
    • Memos: Clean titles (no more “# Case Summary”), real headings, bordered tables and working links. Symbols now show as typed, and each memo holds only its own body text.
    • Outlook email from the Smokeball Desktop App: Tables keep their borders and columns. Accents, em dashes and curly quotes no longer turn into “?” on Classic Outlook.
    • Outlook email from the Smokeball Web App: A fully formatted draft opens in your own mailbox, with the matter files attached. Before, it was plain text.
  • The list of available models now include GPT-5.6 Terra (and Terra Thinking), Claude Opus 5.5 and Claude Sonnet 5.5. Older models have been retired, and GPT-5.2 stays the default.
  • Staff middle names now show in the email recipient list.
  • Fixed the following bugs in Chat and Drafting modes:
    • Revising a draft Archie wrote earlier no longer drops or renumbers clauses it wasn’t asked to touch.
    • Attaching lots of documents (~75+) no longer breaks the chat.
    • Clear History no longer gets slower every time it’s used.
VIC Conveyancing matter types now allow for the entry of multiple unregistered lots in a plan. Learn more about this change in Property Details - Title Particulars - Unregistered Lots (VIC).
10th November 2026
Version 10.2 of the Smokeball Desktop App is gradually rolling out to all users. If you are not receiving a prompt to update, log out and back in to the Desktop App.
Version 10.2 contains the following new features and refinements:
Reset your internal reference automatically in the new year
If your firm has automated matter numbering enabled, you can now turn on a setting that resets the numbering to 1 at the start of each calendar year. The first matter created in the new year will be numbered "1".
To access this setting, navigate to Smokeball Settings > Matter Number and tick Reset Auto-counter at the beginning of the new calendar year.
Notes:
  • You must have Use auto-number enabled.
  • The matter number must contain a Date (YY) or Date (YYYY) component.
  • The Start from number is no longer relevant once Reset Auto-counter at the beginning of the new calendar year is enabled.
Read more about resetting your matter numbering at the beginning of a new calendar year.
Change the font and font size in PDF form text fields
When completing a PDF form in Smokeball, you can now change the font as well as the font size of the form fields. Changes can be applied to a single field, to every field on the current page, or to every field in the whole document in one action.
Learn more about changing the font and font size in PDF form fields.
9th November 2026
The Archie Bank Statement Analyser App has been updated:
  • Fixed an issue where some screens would crash when large files were uploaded for analysis.
  • Statements that aren't analysed are now marked as Not analysed. This status can be found from the row menu.
  • Fixed an issue that was causing the "no transaction data was provided" error.
  • Fixed an issue where large multi-statement PDFs (e.g. multi-year subpoenaed statements) stopped at 40% with "Unexpected token '<'". Splitting the PDF now runs in the background and retrying an upload no longer adds duplicate statements to the matter.
6 November 2026
You can now filter for invoices and matters that have a Payment Plan applied to them, from the left panel of the Invoices, Create Invoices and Reminders screens.
1 out of 1 found this helpful
