Complete an InfoTrack Title Lookup and eCOS for NSW Purchase Matters
Utilising your InfoTrack Integration, on an NSW Purchase matter you can now populate Property & information from a free Title extract and Vendor,  Vendor Solicitor and Agent details from the eCOS ID, saving you time and eliminating the chance of typographical errors.
Title Lookup
Look up the property using the title reference or property address
The title extract information is shown
Choose to create the matter and just populate the property details and council, OR enter the eCOS to populate extra information supplied from the eCOS, such as, Vendor, Vendor’s Solicitor and Vendor’s Agent.
To populate from the eCOS, the user must enter the eCOS ID and any purchasers' last name and press Create
The eCOS ID and purchaser’s last name are verified by InfoTrack to be valid and matching for the supplied title reference. If they match all available information will be populated.
If they do not match, then only the property details and council from the title extract are populated.
If any potential matches are found for contacts, the user will be prompted with the contact review screen.
Select an Option and Click on OK to apply and populate the matter
Create Matter Without Data Pre-Population
You are still able to create a matter without entering anything in the title/address search field.
Simply click Create and the matter is created as normal with no title lookup, no title order, and no pre-population of data.
0 out of 1 found this helpful
