Print a Trust Receipt
You can print or re-print a trust receipt at any time as follows:
  1. Open the matter.
  2. Locate the Trust Receipt you want to print and select the three dots to the right of the balance.
  4. The receipt will then display on a new Smokeball tab, where you can download, print or email it as required.
Generate a receipt automatically after creating a trust transaction
Ensure that your trust receipts are always generated after processing a transaction by enabling this in Firm Settings.
  1. Go to Firm Settings in the Smokeball Web App, then select Accounts from the left panel.
  2. Turn on all options under Trust and Controlled Money Options and click Save.
0 out of 1 found this helpful
