Use Smokeball to easily manage all of your trust accounts.
This is helpful if your firm is switching to a new trust account or manages multiple trust accounts across different states.
Add a new trust account
Select the Settings (gear) icon in the Smokeball Web App, then select Firm Settings.
- Select Accounts from the left menu and remain on the Trust & CMA Settings tab.
Select Add Trust Account.
Enter the bank account information of the new trust account, then select Save.
- Make sure to select the correct state. You cannot amend this later.
- The Display name is shown internally and helps to differentiate between trust accounts when adding payments to an invoice.
- Receipts and other client-facing documents display the full name of the trust account.
Edit existing trust accounts
- Open Firm Settings, then select Accounts from the left menu.
- In the Trust & CMA Settings tab, click on the existing trust account in the Trust Account list.
- Make any required amendments to bank account details and/or the Display name.
- Click Save.
Set default trust payment account
The default payment account feeds through to draft invoices, so you can pay the amount from Trust.
If you do not set up a default payment account, you cannot pay funds from the trust account when creating an invoice.
To set up default payment accounts per state:
- In the Trust & CMA Settings tab, Select the Default Payment Account in the dropdown menu, for each state if relevant.
- Click Save.
You can also set up the default trust account on a matter-by-matter basis.
Open the matter in the Smokeball Web App and select Edit Matter.
- Go to the Trust Settings section.
Select the required account in the Default Account for Trust Payments drop-down menu.
- Click Save Matter.
Note: You can only pay from the Default trust account when creating an invoice.
Configure trust transaction numbering
Each trust account has a different cheque numbering system. Set up the numbering for each Trust account:
- Select the Trust Transaction Numbering tab.
Select the trust account to configure in the dropdown menu.
- Enter the numbering you wish to start with.
- Click Save.
Learn more about Trust Transaction Numbering.
Close a trust account
- Open Firm Settings, then select Accounts from the left menu. Remain on the Trust & CMA Settings heading.
- Double-click the trust account you wish to close from the Trust Account Settings list.
Select Close Account.
You cannot close a Trust account with unreconciled items.
View closed accounts
You can view transaction histories for trust accounts closed in Smokeball.
- Select Show closed accounts above the Trust Account Settings list.
The old trust accounts have a Closed tag.
