Learn how to open, manage and run Controlled Money Accounts (CMAs).
CMAs are specific bank accounts designed to hold your clients' funds. These accounts are different from your Trust Account and accumulate interest and bank fees.
CMAs are necessary when holding a significant amount of your client's money for an extended period, such as when purchasers buy off-plan properties, and your firm is responsible for safeguarding their deposit funds in a CMA.
Set CMA transaction numbering
In your Smokeball Firm Settings, you can set your CMA reference number.
- Select the Settings (gear) icon in the Smokeball Web App, then select Firm Settings.
 - Select Accounts from the left panel.
- Click on the CMA Transaction Numbering tab.
- Enter the starting transaction numbers for receipts and electronic payments in the CMA.
- Select Save.
Opening a New CMA
To open a new CMA for a client:
- Open the matter and select the Transactions tab.
- Select Controlled Money Account from the left-hand panel.
- Select Add Account.
- Enter the details of the CMA:
- Account opened date
- Financial Institution
- Account Name
- BSB
- Account Number
- Beneficiaries
- Select Open Account.
Once a CMA is open, you will see it listed under the âControlled Money Accountâ section on the left-hand menu:
Using a CMA
Within each CMA, you can:
- Select Deposit Funds to deposit funds into the CMA. Note that if you're transferring funds from your Trust Account to the CMA, remember to record the trust payment in your Trust Account.
- Record a payment out of your CMA before closing the account by selecting Payment. The following Payment Types can be recorded:
- Bank Cheque
- Bank Transfer (Direct Deposit or BPAY)
- Direct Debit
- Trust Cheque
- Record a bank fee charged by the bank by selecting Bank Fees.
- Record interest incurred by selecting Interest.
- Print out a CMA Movement Record/Ledger/Transaction History by selecting Print. You can also use the printout to assist with reconciling your bank statements outside of Smokeball.
Edit or close a CMA
From within the CMA, select Account Settings.Â
To make changes to CMA details, update the relevant fields here and click Save.
To close the CMA, select Close Account in the bottom-right corner.
- You must enter a reason and internal note before closing the account.
- You cannot close CMA accounts if there is a balance in the account. All funds must have been paid out to close the account.
Reporting on CMAs
The Trust Statements report displays a separate table for CMA transactions when you run the report for your matter.
For compliance reasons, the End of Month report contains a listing of all open CMAs on an extra page as required by the Law Society. This will show even if a firm does not have any open CMAs, which will be displayed as âNo entries foundâ (see the below example).
If your firm has open CMAs (even if the balance is zero), it will list the CMA accounts (see example below). The listing will continue over multiple pages if the firm has numerous CMA accounts.
