Bubble by Red Cactus Integration
Plan_BoostGrowProsper.svg
Bubble is an integration application by Red Cactus/Access4 that can connect your phone system to Smokeball.
Red Cactus is a connector between your phone system and various CRM applications on your PC. Refer to the Red Cactus Marketplace pages below for compatible applications:
Learn more about how Smokeball integrates with Bubble and how to implement it for your telephony system.
What can you do with the Bubble by Red Cactus integration?
Once connected to Bubble by Red Cactus, incoming callers from your Smokeball contacts will show options to open their contact card and related matters in the Smokeball Web App.
You can also record call notes that sync to Smokeball as a time entry after you wrap up the call.
Notes will appear in the Description section of the time entry.
How to get support for the Bubble by Red Cactus Integration
If you require assistance with the Bubble by Red Cactus Integration with Smokeball, submit a help request on the Access4 website.
1 out of 3 found this helpful
