Convert a lead to a matter
Once your firm has received a signed fee agreement or has accepted a new client, you can convert the lead created in Smokeball into a matter.
In the Smokeball desktop app, select the Convert to Matter button above Lead Details to start the process.
After selecting Convert to Matter, Smokeball displays a window to choose the Matter Type.
Note:
  • If Smokeball has a Matter Type with the same name in the same category, Smokeball will auto-select it, otherwise, Smokeball will fall back to expanding the same category.
  • At the bottom, Smokeball shows the current Lead Type of the Lead and the Matter Type selected that the Lead would change to.
Converting a lead to a matter is not a reversible process. You'll be presented with a confirmation box to check if you still wish to proceed.
  • If the Lead Type and Matter Type are 100% compatible, the user will see the following prompt:
  • If the Lead Type contains contacts or layouts that do not exist in the Matter Type the Lead is changing to, you will see a warning prompt. Please note that leads currently only contain contacts.
    • Any incompatible data will be removed when converted.
    • Make a note of the data before conversion for placing in the converted matter. Memos or contact cards can hold data in the new matter.
  • Once converted, the heading color changes from dark green to dark blue and the icon changes from (L) to (M).
    If you've enabled automatic matter numbering, Smokeball assigns a Matter Number/Internal Reference.
Leads in the web app can also be converted to a matter. Open the matter in the web app and then select the Convert to Lead button.
25 out of 30 found this helpful
