Create a Lead
Plan_BoostGrowProsper.svg LeadPro_MatterFlow.pngCreating a Lead in Smokeball is similar to creating a new matter. Use the tabs below to learn how to create a lead within each version of Smokeball.
Smokeball Desktop (Grow/Prosper+) Smokeball Web (Boost)
Creating a Lead in Desktop (Grow/Prosper+)
 Note: Grow users must have the Intake addon to create leads.
  1. Navigate to the New Lead button, available in the top left of the Smokeball homepage. The 'New Lead" screen has a search box for locating and selecting the Lead type.
  2. Assign the Lead Type. This is similar to selecting a new matter type.
  3. Assign the Attorney Responsible for the lead.
  4. Assign the Referrer and Referral type.
  5. Record the financial details of the Billing Type and Fee/Estimate provided.
  6. Record any notes into a Memo.
  7. Select Create Lead to create the Lead.
  8. Select Create & Open to open the Lead file and continue to work on it.
From here you can do anything you would normally do with a matter in Smokeball, such as add contacts and parties, schedule events, create tasks or next steps, and automate letters and documents.
When ready, you can convert your lead into a matter.
Creating a Lead in Web (Boost)
Note: Boost and Grow users must have the Intake addon to use this feature.
You can create leads in the Smokeball Web App as well.
Follow these steps:
  1. > Select Matters from the left menu, then select the Leads tab.
  2. Select Add Lead.
  3. Choose whether the lead is an individual or an organization, then enter their details.
  4. Select Save.
The Leads tab is where you will find your list of existing leads. You can also use the Search bar on the top-right corner of the web app to find specific leads.
If you have access to the Intake addon, you can also create your own custom intake forms.
12 out of 28 found this helpful
