Create a shortcut in the Forms and Templates Library
Smokeball has a robust library of Court & Authority forms. You can navigate or search for forms, but if you find yourself using a specific form frequently, it is best practice to create a shortcut.
Shortcuts can be used in multiple folders for quick access when generating forms and templates.
Create a shortcut in the Forms & Templates Library
  1. Select the Forms & Templates button in your matter and then select the corresponding matter type folder in the Form Library.
  3. Select a folder in the leftmost to place the shortcut.
  4. Use the drop-down menu or search bar on the rightmost pane to locate your form.
  5. Select your form and then select the Add shortcut link.
    • Note: You can select multiple forms at once by holding down the ctrl key. blobid1.png
  6. The shortcut is added to the bottom of the list of documents on the center pane and is indicated by the blue arrow next to the file icon.
    • Note: You can select the shortcut and hold down the left-click button of your mouse to drag it up and down the center pane. blobid2.png
  • You can right-click on a shortcut to delete it.
  • It is also possible to create a shortcut by holding down the left-click button of your mouse and dragging and dropping the form to the desired location.
2 out of 7 found this helpful
