E-filing with InfoTrack
Smokeball's integration with InfoTrack makes it simple to file court documents, check on the status of acceptance, and see the history of a case docket.
How to e-File with InfoTrack
  1. From any Matter, select eFiling and log into your account.
    • If you are creating a new case to efile for, select "create case" and follow the prompts.
    • If you are e-filing into an already existing case, select your location and search by case number or party name to locate the appropriate case.
  2. When you are ready to file click "file into case."
All details from your Smokeball Matter will be available.
  • Work from the top down to fill in additional details that were not entered in Smokeball.
  • It is easy to upload documents from Smokeball. Any Word files can be converted to PDFs for e-filing as well.
    • Note: InfoTrack will convert the document to the court preferred format (PDF, PDF/A, etc.)
One of the biggest benefits of being a Smokeball Client is InfoTrack can pay any fees upfront for e-filing and invoice you monthly for all the fees you accrued.
  • Choose to "Save as Draft" if you need to make changes.
  • Choose "Validate Fees" to move forward with your e-filing. Once you've validated, you can submit your e-filing.
InfoTrack has an optional feature to request a hearing date and time once you e-file.
You will receive confirmation for your e-filing being accepted and any Court Filing that was scheduled.
The stamped e-filed document will automatically be saved into Smokeball.
All InfoTrack orders and fee summaries will be listed on the InfoTrack tab of every matter.
  • InfoTrack fees can easily be added as expenses for invoicing through Smokeball.
0 out of 3 found this helpful
