One of the powerful features of Smokeball's Personal Injury-Plaintiff matter type is the ability to generate a settlement statement.
This article walks through how to set up and generate a settlement statement in Smokeball.
It is important that important information is entered under Medicals & Settlement Statement as well as track your firm costs (expenses).
By using the Personal Injury-Plaintiff matter type, generating a settlement has never been so easy.
How to Set Up the Settlement Statement
How to Generate the Settlement Statement
- Select Settlement Statement in Medicals & Settlement Details
- Enter your settlement statement and attorneys fees
- Under each line item, select the link to customize your options
- Attorneys' Costs will be automatically added from Smokeball Expenses, but you can choose to manually enter any Attorneys' costs by selecting "manual entry"
- Medicals will auto populate based on information enter in Medicals and Liens & Balances
- If desired, select the line item and use the arrows to move the line item up or down
- To edit standard items and how you want your settlement statement to appear on all PI-Plaintiff matters, select "Standard Items"
- The checkboxes add or remove options
- The arrows on the top right allow you to move line items up or down
- You can also select standard options for attorneys' fees, attorneys' costs, and medicals by selecting the "click to select links"
- Once you have set up your settlement statement, locate the Settlement Statement template under "Forms"
- The settlement statement will be created in Microsoft Word for all document management features available in Smokeball.
