Connect InfoTrack to Smokeball
Learn how to integrate your InfoTrack account with Smokeball for easy access to their services directly from Smokeball.
Don’t have an InfoTrack account? Get started from the InfoTrack website.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Infotrack (https://www.infotrack.com.au/).
Connect InfoTrack via Smokeball Settings
  1. Select the Settings (gear) icon on the top-right corner of Smokeball to access Smokeball Settings.
  2. Select Integrations from the left panel, then select InfoTrack.
  3. Tick Automatically save completed orders to your matter and/or Automatically create a disbursement for each order (optional, but recommended).
  4. Select Authorise.
  5. Follow the prompts to enter your InfoTrack username and password, then select Authorise.
  6. Select Save.
Now you can access InfoTrack features in Smokeball. Learn more about using InfoTrack within a matter.
2 out of 4 found this helpful
