Add, edit or remove a Smokeball user
Learn how to add and edit staff and users in your Smokeball firm.
To begin, follow the steps relevant to your Smokeball plan:
Add a user in Smokeball Grow or Prosper+
    Adding a new user if on a Smokeball Grow or Prosper+ plan can only be done through the Desktop App.
  1. From the Smokeball home screen, select the Settings (gear) icon on the top-right corner.
  2. Select Staff & Users from the left panel.
  3. Select Add New under the Staff & Users section.
  4. Enter your new staff member’s information. The minimum requirement is to enter their name and email address.
    We recommend entering the following information for each staff member to start off:
    • Name: Enter the full legal name as this will populate the signing fields in documents
    • Initials: This shows up in matters to show who has completed certain tasks
    • Contact Details: This will populate in relevant precedents and containers
    • Role: Enter the role that displays under the user’s name when signing
    • Solicitor number: This will populate the practising certificate number fields
  5. Select Enable Smokeball Access for this user. This will add a user licence to your firm's bill.
    The staff member will also receive an email to activate their Smokeball login. Note: The Get Started link will expire after 7 days.
  6. You can also set their default hourly rate and settings here from the Billing tab at the top of the window.
    • If your firm has the AutoTime add-on, you can enable AutoTime for this user by ticking Enable automatic creation of time entries.
  7. Select Save once done, then select Yes when asked to confirm adding the new user.
Edit a user in Smokeball Grow or Prosper+
To edit a user:
  1. Open Smokeball Settings from the top-right corner of Smokeball and select Staff & Users.
  2. Double-click on the staff member's name to open their staff card and make changes.
Remove a user from Smokeball Grow or Prosper+
You can revoke access to staff and users who have left the firm by marking them as Former Staff on their details card.
Important Note: Marking users as "Former Staff" does not reduce your contracted user count or affect your billing. For more information, please contact your Client Success Manager.
Staff & Users in Firm Settings allow you to add new users and edit the information of existing users in Smokeball Boost and Smokeball Bill.
Important Note
Please note that multiple users cannot have the same email address entered as part of their user profile setup.
If the system picks up the conflict when you're setting up a new user profile, you will see the following error message come up.
It may be that a former user still has the email address attached to their user profile.
In this case, you will need to open the former user profile and erase the email from this profile before adding it to the new user profile.
Add a user in Smokeball Bill or Boost
  1. In the Smokeball Web App, click the Settings (gear) icon in the bottom-left corner and select Firm Settings.
  2. Select Staff & Users from the left menu.
  3. Select Add User and enter details.
    • Fill out the staff member's details and provide an email address. You can also add the staff member's hourly rate here or specify if their time is billed in units.
  4. Select Save.
  5. The user will receive an automated email to create a password for Smokeball.
    • Note: The link in the email will expire after 72 hours.
Edit or Remove a user in Smokeball Bill or Boost
  • To edit an existing staff's details, click on their name in the Staff & Users section of Firm Settings.
  • If you need to remove a staff member, toggle on the Is a Former Staff Member option and click Save.
    • Note: It is better to add a new user than to edit/change the information of a former staff member.
35 out of 54 found this helpful
