Learn how to enter credentials such as lawyer's code and state-based identification numbers in Smokeball Settings.
Follow the steps below if you need to enter any of the following:
Federal
- Lawyer's code
NSW
- LRS Box Number
- LRS Customer Number
- Revenue NSW Client ID
QLD
- Land Registry Lodger Number
- OSR Client Number
SA
- LTO Agent Code
VIC
- Firm LSB Number
- LTO Customer Code
- LTO Form APA Approval Number
- LTO Form APR Approval Number
- LTO Form ASP Approval Number
- LTO Form MCP Approval Number
- LTO Form M1A Approval Number
- LTO Form M1B Approval Number
- LTO Form T2 Approval Number
- LTO Form T3 Approval Number
- LTO Form A1 Approval Number
- LTO Form L Approval Number
Enter numbers
- Select the gear icon from the top-right corner of Smokeball.
- Navigate to the Firm Details tab in the Smokeball Settings window.
- Scroll to the bottom of the section to find Box, Customer & Licence Numbers.
- By default, it will display the relevant numbers for your firm's state. Select the drop-down menu to choose Federal or other states.
- Click on the Number field next to the number you wish to add, then start typing the number in.
- Select Save.
