Family Workflows
This article outlines some example workflows for Family Law matters. Since every law firm and jurisdiction may be a little different, we encourage you to edit these workflows based on your own preferences or jurisdictional requirements.
If you are new to Smokeball and Workflows, we recommend that you first learn how to create a workflow. It is easy to assign tasks to an attorney responsible, person assisting, or specific staff members.
Below are some of the workflows you can create for Family Law matters.
Scheduling Order with set Dates
Scheduling Order based off Trial Date
Deposition
Response to Discovery Served on Our Client
Scheduling Order with Set Dates
Some jurisdictions issue scheduling orders with firm dates given for deadlines. If that is the case for you, we recommend using the workflow below. You will assign the due dates to the task upon applying the workflow.
As these tasks are deadlines, we recommend duplicating each task so that one can go to the Attorney Responsible and one task to the Person Assisting. Link the duplicate task to the original task’s due date so that you only need to enter the date once per deadline. The sample below shows how to do this.
Task Name
Due When
Deadline for joinder of additional parties or amendments to pleadings
No due date
 Due date to be assigned upon applying the workflow
Deadline for joinder of additional parties or amendments to pleadings – copy for person assisting
On due date of Deadline for joinder of additional parties or amendments to pleadings
Deadline for Witness and Expert Lists
No due date
Deadline for Witness and Expert Lists – copy for person assisting
On due date of Deadline for Witness and Expert Lists
Deadline for Discovery to be completed
No due date
Deadline for Discovery to be completed – copy for person assisting
On due date of Deadline for Discovery to be completed
Deadline for Motions to be filed
No due date
Deadline for Motions to be filed – copy for person assisting
On due date of Deadline for Motions to be filed
Deadline for Trial Brief
No due date
Deadline for Trial Brief – copy for person assisting
On due date of Deadline for Trial Brief
Some jurisdictions issue scheduling orders with firm dates given for deadlines. If that is the case for you, we recommend that you use the workflow below. You will assign the Trial Date upon applying the workflow which will then calculate the dates for the other tasks.
As these tasks are deadlines, we recommend duplicating each task so that one can go to the Attorney Responsible and one task to the Person Assisting. Note that task duplication is not depicted below, as this scheduling order shows different deadlines. Remember to use these samples as guidelines while customizing them for your firm.
Task Name
Due When
Trial Date
No due date
Deadline for Written Discovery
120 Days before Trial Date
Deadline for Witness List
180 Days before Trial Date
Deadline for Expert List
150 Days before Trial Date
Deadline for Deposition of Witnesses
90 Days before Trial Date
Deadline for Deposition of Experts
60 Days before Trial Date
45 Days before Trial Date
Deadline for Pretrial Conference
30 Days before Trial Date
Deposition
This is a workflow you can apply when you set the calendar date for a deposition.
Task Name
Due Date
Deposition Date
No due date
 Assign the date upon applying the workflow
Prepare questions for deposition
3 weeks before Deposition Date
Get Court Reporter for deposition
2 weeks before Deposition Date
Assign location for deposition
10 days before Deposition Date
Confirm deposition with all attendees
3 days before Deposition Date
Confirm Discovery Request has not been received or incomplete
Task Name
Due Date
Our response to discovery due
No Due Date
Send discovery to client
On the date this workflow is applied to a matter
 Can attach a template for a letter explaining Discovery process to client
Check in with client re discovery
2 weeks before Our response to discovery due
Get all discovery and draft responses
1 week before Our response to discovery due
Finalize responses and get client signatures
3 working days before Our response to discovery due
Send Discovery to Opposing Counsel
On Finalize responses and get client signatures is Completed
You can also download .txt files of each sample workflow described in the article above and import them into Smokeball.
5 out of 5 found this helpful
