Set up default hourly rate
You can enter a default hourly rate for each staff member that uses Smokeball using the below method.
  1. Ensure you have activated enabled the integration of Time & Expenses in Smokeball Settings.
  2. From the Smokeball Settings Staff & Users tab, double-click on a staff member's name to open a staff card.
  3. Select the Billing tab.
  4. Enter your hourly billing rate.
  5. Select Save.
8 out of 9 found this helpful
