Troubleshooting issues with opening or updating Smokeball
Plan_GrowProsper.svg
This guide will provide the necessary changes to your antivirus settings should you be experiencing issues that include any of the following:
  • Unable to update Smokeball to the newest version
  • Unable to open Smokeball after updating or installing
  • Smokeball Outlook and/or Word add-ins failing to start or function after updating or installing
  • Error code AV001
List of exceptions
To resolve any of the above issues, you will need to add Smokeball as an exception to the affected computer's antivirus software.
  • If needed, refer to your antivirus software’s help documentation on adding exceptions.
  • If applicable, refer this article to your IT administrator or IT team if your firm's antivirus software is managed by them.
Ensure that the following folder/file paths have been added as an exception.
Folder path:
  • C:\Program Files\Smokeball
File paths:
  • C:\Program Files\Smokeball\binaries\Smokeball.ServiceRestart.exe
  • C:\Program Files\Smokeball\binaries\Smokeball.WindowsService.Host.exe
  • C:\Program Files\Smokeball\binaries\UriHandler.exe
  • C:\Program Files\Smokeball\binaries\Chrome Bridge.exe
  • C:\Program Files\Smokeball\binaries\Chrome Saver.exe
  • C:\Program Files\Smokeball\binaries\DatabaseValidation.exe
  • C:\Program Files\Smokeball\binaries\Logout.exe
  • C:\Program Files\Smokeball\binaries\PrintToSmokeball.exe
  • C:\Program Files\Smokeball\binaries\Smokeball Scan.exe
  • C:\Program Files\Smokeball\binaries\Smokeball TrayIcon.exe
  • C:\Program Files\Smokeball\binaries\Smokeball Universal Scanner.exe
  • C:\Program Files\Smokeball\binaries\netfw\SmokeballToolbarAddIn.dll
  • C:\Program Files\Smokeball\binaries\netfw\Smokeball.OutlookAddIn.dll
  • C:\Users\<user>\AppData\Local\Temp\Smokeball
Websites
Additionally, you can check this AWS page to make sure Smokeball isn't getting blocked by a firewall.
Once you have added Smokeball as an exception, make sure you restart your computer before re-attempting to update or open Smokeball.
1 out of 16 found this helpful
