Updating Smokeball
When a new version of Smokeball is available, you will be prompted to download it in the following areas.
Updating the desktop app
Dialogue window upon opening Smokeball
Smokeball Home Screen
When accessing Smokeball Settings, you can view your current Smokeball version and the version number of the latest version if there is a discrepancy.
I don't see a prompt to update Smokeball
If an update is available, yet you are not prompted to update Smokeball, we recommend downloading the latest version of Smokeball from our website and running the program on your computer. The installation file also acts as an updater, and will detect and update Smokeball to the latest version.
Updating the web app
When a new version of Smokeball is available on Smokeball Web App, a prompt to Refresh the page will appear in the top-right corner. Select Refresh browser to update.
4 out of 51 found this helpful
