Customise your home screen
Upon opening Smokeball, the first screen you see should present the most important information to you at a glance. Learn how to customise this view so you can focus on what's most important to you in your role.
The buttons on the left-hand side of the Smokeball home screen allow you to access various views.
Set a view as default
To set one of the views in the left-hand panel as the default view displayed when opening Smokeball, right-click on the view icon and select Set as Default.
Use the Smokeball dashboard
If you're subscribed to Smokeball Prosper+, your default home screen view will be the Dashboard, which summarises all your work and displays it on one screen using custom widgets.
Learn more about the dashboard and the types of widgets you can add to it.
8 out of 13 found this helpful
