By default, you cannot move files out of the base form suites in the Smokeball Forms & Templates library to another folder. Base form suites are denoted by a white rectangle in the upper-right corner of their folder icons.
If you need to move a file from a base form suite, follow this workaround:
- Right-click, hold, and drag the form/folder you wish to move from the base suite to the new destination folder.
- Select Copy Here.
- Optional: Delete the original copy of the file in the base form suite.
The first two steps are illustrated in the animation below:
