Billed Fees & Disbursements Report
Use the Billed Fees & Disbursements Report to gain valuable insights into amounts billed and staff / overall firm performance for a particular billing period. Based on your area of interest, the report allows for grouping of information by either the areas of law, matter types, clients, timekeepers, referrers, introducers or persons responsible.
Please note that the report comes in both a Summary and a Detailed format.
How to access this report
This report is located in the reporting suite of the Smokeball Web App.
You will need to navigate to the Reports menu tab in the Smokeball Web App and click to select either the Summary or Details report type in the Choose a Report column.
Billed Fees & Disbursements - Summary Report
The Billed Fees & Disbursements – Summary report provides a summary view of what has been billed during a selected time period. It allows you to assess billing performance by Area of Law, Matter Type, Client, Timekeeper, Referrer, and Person Responsible.
The following filters are available for this report:
  • Invoice date range (required).
  • Run report by choice of Matter Type, Area of Law, Person Responsible, Timekeeper, Client or Referrer.
    • By default, this is set to Timekeeper.
    • The same options exist for the Subtotal filter, as well as <None>. When you choose a subtotal filter, the Run By filter will display additional information in the report which includes the Subtotal By details.
  • Show Percentage - True or False.
    • If True is selected, the percent of the Run By selection will total 100%. If a Subtotal is also selected, then the Subtotals within the Run By selection will total 100%.
The following columns are displayed in the report:
  • Run By column - This is the first column in the report and will be populated as per the selection made using the Run By filter.
  • Subtotal By rows - This is based on what is selected in the Subtotal filter.
    • The report will not be split up into rows based on the selection made using the Subtotal By filter if <None> is selected.
  • Disbursements Billed
  • Percentage of Expenses
    • This column will only show if Show Percentage is set to True.
  • Hours Billed
  • Percentage of Hours
  • Fees Billed
  • Percentage of Fees
  • Total Billed
  • Percentage of Total Billed
Important Notes:
  • Discounts only apply to fees billed.
  • Write-offs and non-billable entries are not included in this report.
  • The Subtotal filter reflects the percentage of the option that is chosen in that filter (e.g. Timekeeper) and does not reflect the total for the whole report.
Billed Fees & Disbursements - Details Report
The Billed Fees & Disbursements – Details report provides a detailed view of what has been billed during a selected time period at the matter and invoice level. It can be used to verify that your invoices have been billed correctly.
Filters displayed in this report Columns displayed in this report
  • Include GST
  • Run By:
    • Practice Area
    • Matter Type
    • Introducer
    • Person Responsible
    • Timekeeper
    • Client
    • Referrer
  • Subtotal By:
    • Practice Area
    • Matter Type
    • Introducer
    • Timekeeper
    • Client
    • Referrer
  • Level of detail
    • Matter
    • Matter & Invoice
  • Timekeeper
  • Introducer
  • Branch
  • Matter Number
  • Client
  • Matter Type
  • Matter Description
  • Introducer
  • Timekeeper
  • Invoice Number
    • Appears if Matter & Invoice is selected for the 'Level of detail' filter
  • Issue Date
  • Hours Billed
    • Rounded to the nearest hundredth
  • Fees Billed
  • GST Billed
    • Appears if Include GST = True
  • Total Billed
    • Includes GST if Include GST = True
Columns displayed when Level of Detail: Matter
Columns displayed when Level of Detail: Matter & Invoice
Important Notes
  • Discounts are applied to fees billed only.
  • Write-offs are not included.
  • Non-billables are not included.
  • Interest Charges are not included.
  • Surcharges are not included.
2 out of 7 found this helpful
