Enter a disbursement entry
Learn how to enter your firm’s costs, disbursements or disbursements in Smokeball.
Enter disbursements in the Smokeball Desktop App
Plan_GrowProsper.svg
Note: You cannot add anticipated disbursements from the Desktop App, however you can do so from the Web App.
  1. Select an existing matter, then select the Time & Disbursements tab.
  2. Select Disbursements to open the Disbursement entry window.
  3. Enter the date of the disbursement, then enter the following details:
    • Subject (limited to 1000 characters)
    • Description
    • Type of cost
      • Hard costs are costs paid directly to the supplier, e.g. search fees.
      • Soft costs are costs that your firm can choose to pass to the client, e.g. costs of printer paper and ink.
    • Quantity
    • Price
    • GST details, including if Input GST or Output GST are different amounts.
    • Set up activity codes so you can use the Activity drop-down menu to automatically fill in most of these fields and save time entering the same disbursement.
  4. Tick whether the disbursement is Billable, or if you wish to write it off.
  5. Select Save or Save & New to continue entering disbursements.
Note: You can also access the Time & Disbursements window from the Time & Disbursements tab. Any entries created here must be assigned to a matter before saving.
You can also create disbursement entries from the bar at the top of the Disbursements tab in a matter.
Enter disbursements in the Smokeball Web App
  1. Open a matter, then select the Disbursements tab.
  2. Select New Disbursement Entry.
  3. Enter the date of the Disbursement, then enter the subject, description, quantity, and price of the Disbursement.
  4. Choose whether the disbursement should be classified as a Hard Cost or Soft Cost.
  5. Select the toggles to choose whether the disbursement is Billable, or if you wish to write it off.
  6. If Input and/or Output tax is different for this disbursement, enter the amounts in the Input GST/Output GST field.
  7. Select whether this entry is a regular disbursement or an anticipated disbursement.
    • If you toggle the Supplier Paid option, enter the supplier's payment details.
      • This marks the disbursement as paid, so a journal entry dated to today's date will be sent to Xero or MYOB (if your firm uses these integrations).
  8. Attach a receipt to this disbursement if applicable.
  9. Select Save or Save & New to continue entering disbursements.
Edit a disbursement
In the Smokeball Desktop App:
Double-click on the disbursement in the Time & Disbursements > Disbursements tab of the main Smokeball window or within a matter. Make your edits, then select Save.
In the Smokeball Web App:
Click on the disbursement in the Time/Fees > Disbursements tab of the main Smokeball window or the Disbursements tab in a matter. Make your edits, then select Update.
You can amend any fields in a disbursement until they are included in a finalised invoice, after which they cannot be edited. Revert your invoice back to a draft state in order to edit the disbursement.
Delete a disbursement
To delete a disbursement, right-click it and select Delete Disbursement.
To delete a disbursement, click on it and select Delete Disbursement at the bottom of the entry.
You cannot delete a disbursement if it has been included in a finalised invoice. In this case, revert the invoice back to draft before you delete it.
Good to Know
  • To calculate GST on the disbursement, you must enter at least the number 1 in the Quantity field.
  • If you are entering a disbursement that has no GST component (such as court filing fees), you can change the GST amount to 0 in the GST field of the disbursement entry.
6 out of 20 found this helpful
