Organize files and documents in a matter
Keeping track of the numerous documents, files, and attachments associated with a matter is a day-to-day challenge for any law firm. Smokeball solves this problem by providing an easy-to-navigate interface for your files at the bottom of each matter.
How to navigate your files
Use the filters at the top of the Documents section to sort through them quickly:
  • Favorites show all files marked as favorites. To add a file to favorites, hover over the file and select the star icon next to it.
  • Documents show all document files, such as Word docs and PDFs.
  • Communicate shows all files shared via Communicate, Smokeball’s secure messaging system.
  • Emails show any email correspondence around the matter.
  • InfoTrack shows all files related to InfoTrack.
Create folders to organize files
Right-click any blank space on the documents section to create a new folder. You can also press Ctrl+Shift+N on your keyboard.
Search for a file
The search bar allows you to search for keywords that can be located in a file’s title and its contents.
How to customize the files list
Adjust the width of the grey column headers by clicking and dragging a border with your mouse cursor.
Right-click on the grey table header to add or remove columns.
You can also toggle between a folders view and an all-files view by selecting the folder icon or bullet list icon.
  • Use the eye icon to preview an individual file.
Double-click on a column header to sort files by alphabetical order, date, file size, and more.
  • Note: Folders will always appear before individual files. blobid5.png
Use right-click to access file actions
One of the best practices in Smokeball is "right click is your best friend."
If you right-click any document in Smokeball, you will find a variety of options available for file management, such as creating a multiple file .pdf, linking a document to a task, file and serve, and publish online.
You can right-click on any file or folder in the Documents section and select Show history of all files for a comprehensive overview of when files are added, modified, etc.
10 out of 16 found this helpful
