Smokeball Configuration and Settings
As part of our onboarding service, we will help you customize Smokeball for your firm during the configuration call.
Select your plan below:
Grow/Prosper+ Bill/Boost
During the configuration call, we will guide you step-by-step in Smokeball Settings to help you:
1. Set up your firm & users
2. Set up your matters
3. Set up billing preferences
4. Set up document automation and your Forms and Templates Library
5. Configure Outlook and notifications
6. Apply integrations and connect with other software
10 out of 17 found this helpful
